AlanD Posted December 22, 2024 Share Posted December 22, 2024 Hi there the lid cluster cubby on 08 HR is discoloured. Looked at replacing but only available on import. has anyone tried to detach the cover. There are four small screws, two on either side which lifts the front. However can get more than a few mm out of it. Before I wedge something in and prize apart, thought would reach out. may attempt a plain wrap. Quote Link to comment Share on other sites More sharing options...
Zzap Posted December 22, 2024 Share Posted December 22, 2024 (edited) Hi Alan, I was in the same boat as you, I decided imported a cubby i think it was about £150 from memory. In order to fit a replacement cubby, or get access to the door you need to remove the waterfall 1st then unscrew the cubby from the rear of the waterfall. There are a few videos on youtube that show how to do this. Hope this helps! Zzap Edited December 22, 2024 by Zzap Quote Link to comment Share on other sites More sharing options...
