MONKEYSOCKS Posted December 4, 2024 Share Posted December 4, 2024 Any suggestions welcome. Since January I've had the following done, just to help rule some things out. Invidia gemini exhaust Cobra hfc's Front & rear ultra racing braces Front & rear Whiteline arbs & droplinks Tein s springs New oem top mounts and bushings Bilstein b6 shocks Front and rear Polybushed rear lower shock bushes Dba t3 discs all round Performance friction pads Front & rear Goodridge braided lines Japanese racing spacers Tarmacsportz rear camber arms Full wheel alignment in September Knocking is only on uneven road, not over speed bumps. Feel like it's coming from rear left. Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted December 12, 2024 Share Posted December 12, 2024 Are tie-rods and rear shocks all torqued up? Ive had it on another car where i hadnt tightened them up quite enough and that was enough to cause a knocking. Quote Link to comment Share on other sites More sharing options...
MONKEYSOCKS Posted December 12, 2024 Author Share Posted December 12, 2024 Rear shocks are definitely torqued, been told I need new tie rods, next job to do. Quote Link to comment Share on other sites More sharing options...
MONKEYSOCKS Posted December 12, 2024 Author Share Posted December 12, 2024 Was thinking it might be rear upper control arm bushings? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 13, 2024 Share Posted December 13, 2024 Could be one of numerous things. As a process of elimination, try disconnecting both rear drop links and take it for a short road test. Quote Link to comment Share on other sites More sharing options...
MONKEYSOCKS Posted December 14, 2024 Author Share Posted December 14, 2024 Cheers mate, I'll give that a go. Took the spare tyre out and can't here it as often now, maybe taking the weight off did something. I'll keep investigating. Quote Link to comment Share on other sites More sharing options...
