New Owner - Is this a fair price for steering fix.
NI 350z Owner
After many years of dreaming I’ve finally pulled the trigger on a 2007 350z. It’s low mileage and in good condition but needs a good bit of work.
I’ve been quoted the following but I’m not a mechanic and could do with a little guidance.
Here is what I was quoted:
2 x Front Brake pads £387
1 x o/s steering Track Rod £260
1 x o/s Track Rod End £184
1 x n/s Steering Rod £260
1 x n/s Track Rod End £216
1 x OSF Lower Arm Suspension £280
1 x NSF Lower Arm Suspension £280
Do these seems excessive or about right. This includes fitting and all labour and testing which I was previously was told was £108 per hour.
Thoughts welcome.
What should I go back to the garage and query.
  • Sad 1
I’m with Alex, that’s nearing “pull your pants down” time. Walk away, get at least 2 other quotes. Research locally, perhaps try a social media site such as Nextdoor and ask for mechanic/garage recommendations. Make sure you specify recommendations from personal experience, not brother Joes best mate. You maybe pleasantly surprised.
Just a thought, is this work because of an MOT failure or the garage taking the proverbial?
Good luck with it.
  • Like 2
Nearly 2 grand for all of that at £108 per hour labour 🥲
I would definitely look elsewhere for quotes, you can get a set of Stoptech pads which are arguably better than OEM and someone to fit them for £200 or less, almost half the price.
https://www.torqen.uk/nissan/350z/brakes/pads/512-350z-stoptech-sport-performance-brake-pads-with-hardware-kit-for-brembo-brakes-front.html
All of the suspension components, go for MOOG, Nissan OEM are ridiculous money from the UK.
Definitely should be around £60-80 labour per hour, rather than £108. None of the parts you've listed require any sort of 'specialist' garage, they're pretty simple nut and bolts jobs.
We have some listed here, depending on where you're based:
https://www.torqen.uk/content/11-recommended-garages
  • Thanks 1
First of all, I’m blown away with the response here. Thank you all.
Yes. They are a dealership. Bells of Crossgar. Northern Ireland.
 They have also been looking after my daily driver for years and have always done a good job. They survey the car and give a video walkthrough of the parts that need replacing so you can see exactly what’s wrong. That’s really Helpful.
I’ve asked for the part numbers:
Please see attached part numbers :-
10170036A- FR PAD KIT BREMBO
10470098A-FR DISC
10470098A-RR PAD KI Genuine
48521AL500-TIE ROD
615701349- FR ARM
615701359- FR ARM Genuine
D8520CD725-TRE  Genuine
D8640CD725- TRE
These mean nothing to me but I’ll do more google searching on these tonight.
So now, with this new context, the prices do look expensive but I have to remember that they include all the work and testing too and they would stand by their work which personally means a lot to me.
If the work isn’t specialised then I’ll look around more. I will get another quote or two now. Thanks for all the recommendations. I’ll let you know what happens.
You are all awesome.
10470098A-FR DISC
48521AL500-TIE ROD
615701349- FR ARM
D8640CD725- TRE
Expand
First 3 part numbers are Brembo, they are NOT Genuine Nissan OEM prices.
485210--AL500 - This is a Nissan OEM part number
The next two are NOT  Nissan OEM part numbers
Last two are an attempt of Nissan OEM part numbers, but they are wrong.
Based on this list, here are the correct Nissan OEM products and some alternatives:
Rear discs: 43206-CD005
Front discs: 40206-CD005
Front pads: 41060-CD028
Rear pads: 44060-CD026
Outer tie rods: D8640-CD725 & D8520-CD725
Inner tie rods: D8521-AL500
Front lower arms: 54500-AM602 & 54501-AM602
https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/9006-350z-de-moog-front-left-lower-control-arm.html
https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/9007-350z-de-moog-front-right-lower-control-arm.html
https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/12515-350z-moog-front-passenger-side-outer-steering-tie-rod-end-lh.html
https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/12516-350z-moog-front-driver-side-outer-steering-tie-rod-end-rh.html
https://www.torqen.uk/nissan/350z/suspension-steering/arms-links/172-350z-moog-front-inner-tie-rod-end.html
https://www.torqen.uk/nissan/350z/brakes/pads/496-350z-stoptech-sport-performance-brake-pads-with-hardware-kit-for-brembo-brakes-rear.html
Hope this helps, comment here if you any other questions.
  • Thanks 1
