Help needed involving DE velocity stack air box
Stacks972
Hi all,
 I have tried to find some information on here about the exact year the models of 350s have the velocity stack air box fitted on the DE engine. I think it is 05-07? If some one could confirm this I would greatly appreciate it thank you!
Cheers.
On 14/08/2024 at 19:14, ZMANALEX said:
The only way to know for sure is to inspect the velocity stack.
On 15/08/2024 at 17:11, mr v6 said:
You should also be able to see it by unclipping the air filter cover & removing it along with the filter.
Thank you for the replies.
Is the 'rev up' air box a straight swap with the earlier version?
Will it fit on the intake tube and slam panel air scoop?
Will have to ask the seller for a picture of the inside or take a chance I guess
Edited by Stacks972
