350_Jer Posted August 11, 2024 Share Posted August 11, 2024 I'm not getting my oil light coming on any more when the ignition is turned on. I've disconnected the 3 centre gauges as I've got aftermarket gauges in their place, would this cause the oil light not to come on or would it need a new oil pressure switch? I don't know if it stopped working when I took the gauges out as I only noticed it didn't work a while after I took then out! They seem pretty expensive so don't want to buy one if I dont need one! Thanks Quote Link to comment Share on other sites More sharing options...
Stewal Posted August 13, 2024 Share Posted August 13, 2024 I believe the standard sender unit operates both the gauge and warning light, so I suspect if you reconnect the original gauge pod the warning light would work. You would need to get a look at a wiring diagram to confirm this and see if its possible to fool the car into thinking the gauges are still there in order to get the light working. Quote Link to comment Share on other sites More sharing options...
350_Jer Posted August 13, 2024 Author Share Posted August 13, 2024 Thanks, I'll try reconnecting the gauges, glad I kept hold of them now and didn't get rid of them! Quote Link to comment Share on other sites More sharing options...
