Millsy1969 Posted August 5, 2024 Share Posted August 5, 2024 Hi all. Looking new battery and several posts regarding size etc. The one I have is about 232 ish mm in length and the one I've seen is 278mm which has more Cranking Amps. The tray it sits on looks about 290mm. Will the higher CCA have any effect on the circuit load and does anyone know battery and tray size off hand. Don't want to strip it down yet until after service on fri. Thanks. Quote Link to comment Share on other sites More sharing options...
Chris M Posted August 18, 2024 Share Posted August 18, 2024 It is hard to get the perfect size as the clamp on the JDM cars is really small and the top of a lot of batteries wont fit, If you do go to halfords bring the clamp with you so you can test it. I just bought a UK clamp as that let me use a more nomal battery. Quote Link to comment Share on other sites More sharing options...
Chris M Posted August 18, 2024 Share Posted August 18, 2024 Here is the one I ended up buying: https://www.torqen.uk/nissan/350z/engine/electronics/37563-350z-nissan-oem-battery-bracket.html Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 19, 2024 Share Posted August 19, 2024 As has been said best to fit a UK battery and change the terminals and the clamping bracket and rods. Terminals, bracket and rods are all in stock and good to go same/next day. just drop me a pm if I can help you further. Quote Link to comment Share on other sites More sharing options...
Engin Posted November 26, 2024 Share Posted November 26, 2024 I got this one, perfect fit: https://www.tayna.co.uk/car-batteries/varta/b31/?gad_source=1&gclid=EAIaIQobChMIpMGd6-b6iQMVYJdQBh2gwwHXEAAYASAAEgLcGfD_BwE Quote Link to comment Share on other sites More sharing options...
