xbox 360 - was only a matter of time
neo
Its not going to be that easy to market as you have to remove the chip , reflash it and pop it back. Also Microsoft can update the OS so that it will check that the program is valid and upload over the controller, therefore you will be paying cash for nothing.
It will come. My current XBOX is chipped. I cant play xbox live, but I have used xbconnect. which is software that uses your pc to connect your xbox to others.
The very good thing about xbconnect, is that it lets you run some non "live" enabled games that you would otherwise only be able to play using system link.
Im sure the same thing will come for the 360. It will just be a matter of time.
