Zalas Posted May 20, 2024 Share Posted May 20, 2024 As the restoration continues (started by removing a bit of rust on the front crossmember, now complete rebuild and de-rust) I have a couple of weeps. One is on the pressure valve/nut on the steering rack which will be taken care of by sealant around the outside HOWEVER I'm struggling to identify this under the rad. The closest I can come to is 'lower tank' referenced on https://nissan.oempartsonline.com/v-2004-nissan-350z--enthusiast--3-5l-v6-gas/cooling-system--radiator-and-components - it's in the same horizontal line as the rad drain plug and lower hose attachment. Any thoughts? Right hand side just below the clips where the fan shroud sits. Two pipes (RH and LH) run from the auto-box to the radiator and back again so i assume an integrated trans-cooler and rad. I'm hoping it's as simple as re-sealing the union/thread with a washer and pipe jointing compound for good measure? Thanks. Al. Quote Link to comment Share on other sites More sharing options...
