Jako81624 Posted May 10, 2024 Share Posted May 10, 2024 Hi all - just a posterity post. I designed an adapter plate for Wilwood/Tilton style Clutch Master Cylinders. Basic directions are provided on the repository alongside some photos - all in, you can probably cut and fit this for about £30 if you use a local engineering shop and decent hardware. It cost me ~£14 to get it laser cut from 316 Stainless from a local shop. I went for A4/316 hardware from Accu.co.uk so you could definitely save some money there if you wanted to, but I stuck to the theme. Here's the repository - the design files are under Clutch-System/Master-Cylinder License is CC-BY-SA 4.0. Sell it if you want - all that's required is crediting the source (if anyone wants to financially compensate me in some way I probably won't decline, but it's absolutely not necessary!). All modifications to the design must be shared under the same CC-BY-SA 4.0 license. Hope this helps someone. Seems to be the most cost-effective option if you have a decent machine/engineering shop around. (Andover Laser are the best-priced online service in the UK I can find. About £40 from 316, so you still have about £40 in the tank before being priced out by the only other standalone adapter on the market) 1 Quote Link to comment Share on other sites More sharing options...
