350z high idle issue
Ryan Jones
I have noticed that my 06 350z is idling a bit high at around 950-1k when warm if I am stopped waiting at lights ect. I have just left it for a bit but then the other day I switched the car off and back on a again once it was warm while I was waiting at the lights and the idle goes back down to 650-750rpm and stays like that for the rest of the drive which I would consider a more normal idle speed. There is no engine light on at the moment and I have tried the pedal dance before. I think it helped in that past a bit but still doing it now.
any advice?
I do have a code reader but have lost the charger so I’ll try to find that to see if anything comes up on it but like I say there is no current engine light showing.
I just used plenty of carb cleaner. I opened the throttle body & gave the whole inside a good clean, along with the edge of the butterfly valve, then do the resets, that may take you numerous attempts as they can be tricky.
  • 1 month later...
