gh9886 Posted March 21, 2024 Share Posted March 21, 2024 Hey all, I recently changed the clock spring on my '07 HR 350z, due to the horn no longer working. Since doing so, the airbag light has started flashing. The flash pattern I'm getting is 1 long followed by 1 short. A scan with NDS II revealed the following error code: b1081, pre-ten front rh. No accidents or malfunctions were witnessed, and airbags have not deployed during the car's lifetime. I can't clear the error with NDS II. Unsure if this is a common issue, or if I'll need to replace the SRS module? Anyone have experience or knowledge on the issue? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
mr v6 Posted March 21, 2024 Share Posted March 21, 2024 Just a suggestion, did you disconnect the battery first? Also, are you able to reset the steering angle sensor in case that's the issue? Quote Link to comment Share on other sites More sharing options...
