vortech impeller swap
v6bandit
Hey UK people
I need a new impeller for my vortech v3 centrifugal supercharger but they are expensive.
I found a china supplier that makes a billet aluminum impeller that's a slightly different design and that's a bit smaller but would still fit in the housing and give about 3mm gap clearance in the outlet.
So why can't I run a smaller impeller hmmm? Tell me why, and I know one of you guys is gonna say something about efficiency or something but you know this blower is already rated for 800HP and I only need about 8psi for around 400 HP. So then the slightly smaller impeller should work then right?
Honestly I'm not about to spend 500 bucks on a aftermarket impeller when they can be had for a fraction of the cost.
Ps. Please don't make fun of me for being cheapo. 😭
I don't think it will disintegrated because they list the specific metal type and the 500 dollar aftermarket ones are of similar quality and design.
I just want to know what the effects of running a smaller turbine are which doesn't fill the volute to the same tight tolerances.
I had a new impeller fitted and used vortech themselves in the states I took the opportunity to upgrade to the si impeller over the sci which netted a few more psi
I definitely wouldn't trust anyone other than vortech to do the job and I don't think they will sell you parts
This being said I did come across a UK guy the other day thats rebuilding a load of chargers and seems to do things correctly so might be worth a chat with him regarding the aftermarket impellers you talk of
https://www.facebook.com/UKSuperchargerRepairs
Good luck
