Nake Posted December 8, 2023 Share Posted December 8, 2023 (edited) I need some help to figure out why my 07 HR suddenly started running really rough after replacing the W brace. It sounds like it's not running on all cylinders and after checking with the OBD scanner I am amazed at what's going on with the fuel trimming, but not sure why. I've already changed the plugs, cleaned and swapped the MAF sensors, checked the heater resistance of all O2 sensors, but now thinking it's fuel / fuel starvation related? Maybe a result of jacking up with 1/4 of a tank of fuel? Green and Red are B1 and B2 fuel trims, whilst Yellow and Blue are B1 and B2 pre cat o2 sensor voltages. Edited December 8, 2023 by Nake Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted December 9, 2023 Share Posted December 9, 2023 (edited) Not nipped a line anywhere have you ? Id get it in the air and have a good look around for any signs of kinks, crush or leaks 👍 Found this: https://www.nissanpartsdeal.com/parts-list/2007-nissan-350z/fuel_engine_control/fuel_piping.html?diagram=173_A003 Has the routing and part numbers if needed Edited December 9, 2023 by Willsy1980 Quote Link to comment Share on other sites More sharing options...
Nake Posted December 10, 2023 Author Share Posted December 10, 2023 23 hours ago, Willsy1980 said: Not nipped a line anywhere have you ? Id get it in the air and have a good look around for any signs of kinks, crush or leaks 👍 Found this: https://www.nissanpartsdeal.com/parts-list/2007-nissan-350z/fuel_engine_control/fuel_piping.html?diagram=173_A003 Has the routing and part numbers if needed What, you're thinking fuel line possibly damaged? I know I can't smell any fuel, but good idea I can check for a crush or similar. Got a fuel pressure gauge now too so that should help. 1 Quote Link to comment Share on other sites More sharing options...
