Forged Wheels Spacers V3 - *TORQEN* - 350z and 370z
Coz@TORQEN
Hi Guys,
We have our new batch of spacers which have had a revamp with a list of improvements, now including cooling channels and removal grooves as well as a knurled design. More details below.
Features:
• CNC Machined - 0.02mm tolerance precision - perfect mounting
• Active cooling technique - symmetrical petal shape grooves for effective heat dissipation and water / debris protection
• Knurling design - reduce internal stress and enhanced heat dissipation
• Full-cone seat - greater force area and safer design
• Hub centric - eliminates the vibration and transfers bolt load
• Removal grooves - makes it a lot easier to remove the spacers, but also improves air cooling
• Forged AL7075-T6 with Tensile Strength ≥ 572 Mpa
• ISO Grade 10 Nuts with BONOSS Engraved, Strength ≥ 1110 Mpa
• ISO Grade 12.9 Studs, Strength ≥ 1220 Mpa - higher grade than the OEM studs at 10.9
• Over 66 SGS TÜV Test Reports Certificated
• 10 Years Warranty
The price is for a pair (2 pcs) wheel spacer, including the required applications(Bolts/Lug Nuts, etc).
IMG_4566.JPG.37fc15ef564522f4ad907fcb738bbec1.JPGIMG_4578.JPG.f833c0a8c0eb27d5a72fa510f54a7c19.JPGIMG_4565.JPG.16a438501a33a91df73e813a160fb52e.JPGIMG_4564.JPG.da7e7127742f888ee6a0c963ac87dd25.JPG
  • Like 2
