Clutch fluid
philipcooper303
Just done this on my drive. I bought the aftermarket set from Horsham Development
https://h-dev.co.uk/product/350z-de-clutch-slave-cylinder-braided-clutch-line-and-high-temp-brakeclutch-fluid-kit/
Very simple job just make sure you prime the slave cylinder with fluid and gravity bleed it for a while prior to bleeding.
I think my fluid was old and boiling point lower. The one in the kit is better quality fluid, I think that combined with braided hose makes the pedal seem more engaging.
I used a flare wrench on the clutch line as you don't want to round the nut. Reuse the heat wrap as the exhaust is close by.IMG_20231116_150001.jpg.8e37036a13ff004f0c98f7f63fe57c92.jpg
This video helped alot.
