Electrical issues
Gavin911
Hello has anyone got any clues or help for me please on the 350z electrics? As I went to a meet last night and on the way all of a sudden my speedo, rev counter, the digital gauge pod, obd2 and heater/blower all stopped working. I've done a cluster self diagnostic and the needles all worked, I've checked all the footwell fuses and there fine. I'm really scratching my head on what it could be? Has anyone ever come across this issue before? Thankyou friends.
If you prefer to replace parts as a process of elimination instead of performing proper diagnoses then the air con module would be a good place to start, followed perhaps by the IPDM and the BCM both these parts control the issues that you are having.
I should have all these parts in stock.
What year and model is your 350?
I've managed to get my obd2 to work, it's chucked up two fault codes
P0181 powertrain fuel temperature sensor A circuit range/performance.
P0463 powertrain fuel level sensor circuit high input.
Does this help in diagnosing my problems?
 Please help a fella out🤞🙏🙏
  • 3 weeks later...
Hi zman, don't know if this will link you to our previous chat lol. I have a 2008 350z coupe the unified meter number I made sure they were the same model mine is 27760 EV00B and the one I ordered from the US has the same number. I don't think there was anything wrong with mine now as I checked pin 21 and 22 on the grey connector to the unified meter with a multimeter and I'm not getting any voltage, if I did it correct lol? Thanks man.
