muzzer Posted September 11, 2023 Share Posted September 11, 2023 My Z is a 2004, so I understand the power outlet needs the ignition to be on to be live. I’m not up to changing the electrics to get round that, as I’ve seen covered on here. I’d like to use a solar powered trickle charger this winter when the battery is vulnerable but I don’t fancy leaving it outside on the windscreen, given the state of the neighbourhood. Is there any route thru from the battery space to the cabin that I could thread the charge leads thru? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
