FrankPZ Posted July 26, 2023 Share Posted July 26, 2023 Been doing a bit of research . So my 2004 DE , like many others, suffers from stiff second gear when cold. This is most likely due to worn inner surface of the syncro ring.. As the oil heats up it lubes the syncro and makes the surfaces "stick" and gear change is then fine. This is not a huge problem but would still be nice to sort. The ring works on friction so if this is the case by all means try new oil but do not add Molyslip as this reduces friction and that is the opposite of what you want. Adding Molyslip has not helped one bit on my Z and now I know why. I used Motul 75W85, has anyone had better luck with a different oil? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 26, 2023 Share Posted July 26, 2023 I have always found that the Nissan OEM fluids work best in this tranny. Choice of 2 below. However, if the syncros are worn then they will require replacement which is not a huge job in the grand scheme of things. Quote Link to comment Share on other sites More sharing options...
davey_83 Posted July 26, 2023 Share Posted July 26, 2023 Mine has always been the same even following a gear oil change with molyslip. After the first 5 - 6mins it's ok and until then I shift 1st to 3rd which is no bother for a big VQ. Quote Link to comment Share on other sites More sharing options...
SWoMP Posted July 26, 2023 Share Posted July 26, 2023 Early cars got offered a gearbox recall for rebuild. Unfortunately I never complained so didn't know about this until outside the Warranty period. Much later, I obtained all the (later-spec) parts and had my gearbox rebuilt and it is now fine. I'd agree with Alex, use the Nissan-spec oil - I've never had the need to add anything to it. You do need to be firm with it, dont rush your changes, and it will be fine (It used to be rumoured that when looking for a box for the 350 they used one that had previously been used on Tractors - good story!!) (Whilst gearbox was being overhauled I obtained a spare box from a low mileage GT4 and that didnt have the problem. As it was the same year as mine I can only assume it had the warranty work done.) Quote Link to comment Share on other sites More sharing options...
FrankPZ Posted August 2, 2023 Author Share Posted August 2, 2023 Update: So changed the gearbox oil again, this time put in Castrol Transmax 75w90. Has not completely cured it, 2nd slightly stiff when cold, but change is much better and I can live with it. 1 Quote Link to comment Share on other sites More sharing options...
FearZ33 Posted January 29, 2024 Share Posted January 29, 2024 I seem to be having an extreme version of this issue. All gears have needed a firm shift since I got the car, but second was a bit difficult to get into, especially when cold. Now it seems to lock out of second more often than not, so I need to shift 1st to 3rd. Double clutching to get second doesn't always work either. Car is a HR with over 80k miles, it had the transmission oil changed with the OEM stuff about 5k ago. Clutch and flywheel are original (as is the clutch fluid by the look of it - but this is going to be the first fix I try). Do you reckon gearbox surgery is on the horizon - or is there a chance it could be to do with the clutch/DMF/CSC being on their way out? I saw in this old thread that a new clutch/flywheel solved someone's 2nd gear issue: Quote Link to comment Share on other sites More sharing options...
