Headlight Washers Not Working
McG
Any troubleshooting advice for headlight washers not working?
I have the headlights turned on and tried short bursts of the windscreen washers but nothing happens with the headlight washers.
On many cars which share the same reservoir the light washers trip long before the bottle is empty to avoid having nothing for the screen. So it is certainly wise to test with a full reservoir before assuming a fault.
Thanks,
I’ve topped the water level up to the top of the input neck and tested it, however I am not sure if the actual reservoir is full as I have read that the neck can get full but not the reservoir, and without taking the bumper off I’m not sure how else to check the fill level of the reservoir.
Don't headlamp washers generally operate only after a few pulls on the screen washer? Certainly for the Z and our Ateca, I only notice them operating after every few occasions that the screen washer is used.
