NikG Posted March 12, 2023 Share Posted March 12, 2023 Hi So been foing some work to the z, snd its passed its MOT (yey). Im thinking about going for the UpRev tuning, probably through Horsham Developments. Now its an old car (2004 DE) so not looking to overstress it or to try and get some crazy hp, but faster throttle response etc would be nice. Just a general tune really. Engine mods so far are: Cat back exhaust (no idea what make) 5/16 plenum spacer Velocity stack on oem airbox (basically a diy version of the later air box) Panel filter Are there any other "basic" mods youd recommend/worth doing before the UpRev tune? Let me know Thanks Nik Quote Link to comment Share on other sites More sharing options...
NikG Posted March 12, 2023 Author Share Posted March 12, 2023 From all the searching ive done the general concensus is that even with those mods the tune would be "worth it" and noticeable, but also happy to hear comments on if you think its a good idea. 👍 Quote Link to comment Share on other sites More sharing options...
Olly350z Posted March 12, 2023 Share Posted March 12, 2023 A damn good service would go along way before carrying out any tune to help you maximise the results and how the car responds. Fresh engine oil, Oil filter, New spark plugs You could add high flow cats to your exhaust system but you start opening up MOT headaches. Just remember anything you change performance wise on the car after the remap should ideally then be re-remapped Quote Link to comment Share on other sites More sharing options...
NikG Posted March 12, 2023 Author Share Posted March 12, 2023 Thanks, yeah im avoiding cat changes! If i can get the basics done pre tune, ill probably leave it there in terms of engine mods. Should have mentioned, full service done. First thing i always do. Years of racing bikes has me dropping oil and plugs probably a bit more often than needed! Quote Link to comment Share on other sites More sharing options...
davey_83 Posted March 13, 2023 Share Posted March 13, 2023 (edited) If you take a near floor picture of the rear end, we should be able to tell you which system you have. With OE cats while they might pass an MOT, they're probably not flowing as well as when new so might nab a few hp. The below is worth a look also 👍 No bolt on n/a mods for the DE show much by way of gains, of course they all add up however this mod went a long way to improving engine pick up throughout the rev range. https://www.350z-uk.com/topic/111683-db-nissan-350z-gt-05/?do=findComment&comment=1833308 Edited March 13, 2023 by davey_83 1 Quote Link to comment Share on other sites More sharing options...
NikG Posted March 14, 2023 Author Share Posted March 14, 2023 ooh thanks, i was tempted with with new pulleys, but mainly cause mine where rusty! lol ive already done the redundant idler pulley removal. I'm away with work this week, but i'll get a picture of the exhaust this weekend. nik 1 Quote Link to comment Share on other sites More sharing options...
DarmoZ Posted April 21, 2023 Share Posted April 21, 2023 (edited) On 13/03/2023 at 21:09, davey_83 said: If you take a near floor picture of the rear end, we should be able to tell you which system you have. With OE cats while they might pass an MOT, they're probably not flowing as well as when new so might nab a few hp. The below is worth a look also 👍 No bolt on n/a mods for the DE show much by way of gains, of course they all add up however this mod went a long way to improving engine pick up throughout the rev range. https://www.350z-uk.com/topic/111683-db-nissan-350z-gt-05/?do=findComment&comment=1833308 I think ill get these done along with my Valve cover gasket job. Tarmac Sportz Nissan 350z Lightweight Pulley and Belt Kit OP: I recommend high flow cats, don't worry about MOT cos you can just run a can of cataclean in your fuel system (£12 from halford) before the MOT and you will get a perfect emissions reading regardless what CAT's are on. Or just have a mate mechanic do your MOT. Edited April 21, 2023 by DarmoZ Quote Link to comment Share on other sites More sharing options...
