Jixaman Posted February 13, 2023 Share Posted February 13, 2023 Hi guys, ok, so car is not running good, fine on startup but starts missing when warmed up so it's parked up again. I have tried two wired scanners that claim to do JDM but don't work and have a Bluetooth Elm with the idea of using NDS II. That's no worked either... Ahv read loads of threads with no definitive answer (the Bluetooth Elm and NDS II was said to work, ahv E'd the NDS people case ahm doing something wrong). Anyway, any help appreciated... Would like to get the codes before I remove anything... Cheers... Quote Link to comment Share on other sites More sharing options...
marzman Posted February 13, 2023 Share Posted February 13, 2023 I assume your scanner specifically says it supports JOBD protocol? Quote Link to comment Share on other sites More sharing options...
Jixaman Posted February 13, 2023 Author Share Posted February 13, 2023 Both wired scanners said so, but there were both positive and negative comments on that, similar to the forum itself... The bluetooth reader ah got to go with the NDS II was as advised to get by them... You know of any that work? Quote Link to comment Share on other sites More sharing options...
rodgeevans Posted February 14, 2023 Share Posted February 14, 2023 Quote Link to comment Share on other sites More sharing options...
Jixaman Posted August 22, 2023 Author Share Posted August 22, 2023 Finally found a JOBD that works, got code, Coil packs ordered (Hitachi), hopefully solves the problem... 1 Quote Link to comment Share on other sites More sharing options...
