Electric Seat Not Working - Fix ✅
davey_83
I would normally update my build thread however, think this might be of wider use as information tends to get lost among pages and pages of chat.
Ever since ownership the driver's seat controls have been temperamental. Sometimes the motor would seem to work after a couple of attempts at the switch or holding the switch for a while or sometimes not at all. Not a huge problem as once the seat is in the correct position, there's little reason to ever move it.
So yesterday the seat decided it'll only tilt forward and not back, great. Sometimes I'd have to operate it for a moment in forward tilt and then it'll move back, but no.
1st action, check for any obstruction under the seat that may have knocked a plug loose. Followed the loom from the switch to first plug disconnected and reconnected. Checked the plugs to the motors and using a power probe seeing simply 12v would feed one pin at at time to operate either backwards or forwards - all seems fine.
2nd Liqui Moly spray grease the switch as might be some contaminate I needed to dislodge. Still no joy and left it at that as it was getting late, working via torch. Started looking around for a replacement switch as couldn't see anything untoward post switch.
Then came across a YT video from a few years ago of a fella using fish tank silicone hose to bulk out the triggers in the switch. The next day (today) after stripping down the switch itself discovered the triggers themselves do in fact operate the motors just fine.
Checking in the tat draw (every kitchen has one) came across a packet of wall plugs that looked just the right size. Cut a few mm of the end to make collars and the size was perfect.
Held in place by my head assistant 😄
Years and years of grime and now lube
If those tiny little prongs don't contact the triggers enough, motors won't operate.
Ends cut off ready
Two with and two without for comparison
Built all back up and works perfectly!! No hesitation at all now and fixed for free 😁
  • Like 4
