Aliensurfer Posted January 27, 2023 Share Posted January 27, 2023 Hi All, 2010 307z here with 55k on the Clock. Did a long drive from Leeds to Edinburgh this week for work and the car was flawless all the way up, but the following morning I had no clutch pressure and couldn't get her into gear. Engine was running for a few minutes while I figured out my next steps, tried again, and went into gear no problem. One the way home she was fine starting off but after about 2hrs of motorway driving with no gear changes, I came off the M6 for the services and the clutch was the same. No pressure and refused to get into any gear. I cruised into the services in Neutral, waited a few minutes, and the gears would work again. Managed to get home but it was very hard changing gear after that. Is this the fabled CSC issues I keep reading about? Would looking to replace that be the first option to look into? Any suggestions very welcome. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 27, 2023 Share Posted January 27, 2023 Sounds like it. Check your clutch fluid level. 1 Quote Link to comment Share on other sites More sharing options...
Aliensurfer Posted January 28, 2023 Author Share Posted January 28, 2023 Clutch fluid level looks ok at first glance, flithy and needs changing, but levels look ok. I'll book it in to get the CSC looked at, thanks. Quote Link to comment Share on other sites More sharing options...
Jack94 Posted January 28, 2023 Share Posted January 28, 2023 If your clutch/flywheel are well worn and you can afford it you might as well get them replaced at the same time seeing as the gearbox has gotta be pulled to access the CSC. 2 Quote Link to comment Share on other sites More sharing options...
Aliensurfer Posted January 31, 2023 Author Share Posted January 31, 2023 Currently sat in Tarmac's waiting room while Bob works his magic! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 31, 2023 Share Posted January 31, 2023 On 31/01/2023 at 11:35, Aliensurfer said: Currently sat in Tarmac's waiting room while Bob works his magic! Expand Quote Link to comment Share on other sites More sharing options...
