colinpal Posted January 13, 2023 Share Posted January 13, 2023 (edited) Hi all,  I had a Scorpion Exhaust with rolled tips fitted yesterday by my local power flow exhaust specialist. It looks and sounds lovely.  However when I got home and inspected, some of the joints are leaking water/moisture (hard to tell if gas escaping). I see exhaust paste has dripped all over the place.  I am taking it back Monday for them to rectify.  Is this normal for new slip joint exhausts? Has anyone else had a similar issue? Any advice for when I take the car back to the exhaust specialist?  Thanks  Colin Edited January 13, 2023 by colinpal 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 13, 2023 Share Posted January 13, 2023 If the flange faces are all flush and you fit proper new gaskets then you should not require any paste. and providing the pipes which are clamped are uniformed and clean, then you should not have any leaks, Pretty basic stuff actually. Â Never had a fitment issue with Scorpion, as decent quality compared to others. 1 Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted January 13, 2023 Share Posted January 13, 2023 (edited) Scorpion wouldn't offer lifetime warranty without being confident with their products. The fitter should get that rectified for you when you go back.  My local Scorpion dealer is also part of the LONGLIFE custom exhaust group. When the LONGLIFE exhaust was blowing on my wife's car between the midpipe and midpipe resonator, it was fixed no questions asked despite the exhaust being fitted about 8 years ago as they said it had a lifetime warranty .  Ps. I went for the same exhaust and the Scorpion y-pipe a few years ago too Edited January 13, 2023 by HEADPHONES 1 Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted January 13, 2023 Share Posted January 13, 2023 Hopefully it's dry and not raining tomorrow and I'll get under my car and take a photo of mine at that same place behind the backbox 1 Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted January 14, 2023 Share Posted January 14, 2023 Here you go mate. Mine is around 2&1/2 years old 1 Quote Link to comment Share on other sites More sharing options...
colinpal Posted January 15, 2023 Author Share Posted January 15, 2023 (edited) On 13/01/2023 at 14:58, HEADPHONES said: Scorpion wouldn't offer lifetime warranty without being confident with their products. The fitter should get that rectified for you when you go back.  My local Scorpion dealer is also part of the LONGLIFE custom exhaust group. When the LONGLIFE exhaust was blowing on my wife's car between the midpipe and midpipe resonator, it was fixed no questions asked despite the exhaust being fitted about 8 years ago as they said it had a lifetime warranty .  Ps. I went for the same exhaust and the Scorpion y-pipe a few years ago too I got my scorpion with rolled tips based on your posts and photos  Your car looks sweet. Thanks for your photos / advice. I will let you know how I get on. After reading around it might just be condensation around the joint and dripping off from vibrations and heat from exhaust but will know for sure tomorrow.  Here is one of the websites I am referring to: https://forum.miata.net/vb/showthread.php?t=145408 Edited January 15, 2023 by colinpal 1 Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted January 15, 2023 Share Posted January 15, 2023 Did the apprentice do the installation 🤔 Quote Link to comment Share on other sites More sharing options...
colinpal Posted January 16, 2023 Author Share Posted January 16, 2023 (edited) 4 hours ago, ShortPaul said: Did the apprentice do the installation 🤔 Not at all. I went somewhere that has a lot of great reviews. They only fit and fix exhausts. He had to a weld a new flange on the y pipe as the existing flange was disintegrating. The rest of the y pipe and cats were ok but we both agreed it was too much of a risk to attempt undoing any of the bolts to replace the y pipe in case it damaged the cats. Edited January 16, 2023 by colinpal Quote Link to comment Share on other sites More sharing options...
colinpal Posted January 16, 2023 Author Share Posted January 16, 2023 (edited) This is old exhaust. It did well for 15 years    Edited January 16, 2023 by colinpal Quote Link to comment Share on other sites More sharing options...
colinpal Posted January 16, 2023 Author Share Posted January 16, 2023 (edited) and this is the new exhaust after fitting    Edited January 16, 2023 by colinpal 1 Quote Link to comment Share on other sites More sharing options...
davey_83 Posted January 16, 2023 Share Posted January 16, 2023 Looks lovely. When the time comes I can recommend an aftermarket y pipe to accompany the new exhaust, as the OE y pipe is meant to be restrictive. 1 Quote Link to comment Share on other sites More sharing options...
colinpal Posted January 16, 2023 Author Share Posted January 16, 2023 A quick update. Took it back to the fitter. There was a small leak coming from one of the joints. The clamp just needed to be loosened, rotated a bit and re-tightened and then all was good. Happy now 4 Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted January 16, 2023 Share Posted January 16, 2023 All that worry eh.........we always worry about being palmed off with shoddy work but in this case they came up good Quote Link to comment Share on other sites More sharing options...
