Olly350z Posted February 25, 2023 Author Share Posted February 25, 2023 Nothing wrong with how I've worded it, you solely jumping to the wrong conclusion and shooting your mouth off. No where did I imply that it had any involvement with Tarmac sportz. Secondly, if you'd looked for even remotely more then two seconds at the pictures you'd see it looks NOTHING like their workshop Now you're getting defensive because you've been called out on it. Take a back seat, sit down and wind your neck in. You should know better 1 Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted February 25, 2023 Share Posted February 25, 2023 WOW. Quote Link to comment Share on other sites More sharing options...
pintopete58 Posted February 25, 2023 Share Posted February 25, 2023 One day hopefully we can speak about this . And laugh about it but I'm not a person who runs away. Thank you for your kind words 1 Quote Link to comment Share on other sites More sharing options...
Coz@TORQEN Posted February 25, 2023 Share Posted February 25, 2023 Just as a heads up, every exhaust fits NISMO. We’ve sold hundreds of exhausts for MK1 and MK2 NISMO and never had a fitment issue to date. The underneath is the same and the only difference is on the OEM exhaust which uses the X Pipe. If you’re changing to an aftermarket system which is catback, there’s no difference whatsoever. Quote Link to comment Share on other sites More sharing options...
Olly350z Posted February 25, 2023 Author Share Posted February 25, 2023 Congratulations on still missing the point. It was a perfectly normal thread until you chimed in and got it completely wrong. Can a moderator please clean this up please? Quote Link to comment Share on other sites More sharing options...
Olly350z Posted February 25, 2023 Author Share Posted February 25, 2023 Just now, Coz@TORQEN said: Just as a heads up, every exhaust fits NISMO. We’ve sold hundreds of exhausts for MK1 and MK2 NISMO and never had a fitment issue to date. The underneath is the same and the only difference is on the OEM exhaust which uses the X Pipe. If you’re changing to an aftermarket system which is catback, there’s no difference whatsoever. If that's the case then why does the ARK grip not fit MK2 nismos? Payco had this exact issue and had to get it modified to fit as it was too short and fowled the differential Quote Link to comment Share on other sites More sharing options...
Coz@TORQEN Posted February 25, 2023 Share Posted February 25, 2023 6 minutes ago, Olly350z said: If that's the case then why does the ARK grip not fit MK2 nismos? Payco had this exact issue and had to get it modified to fit as it was too short and fowled the differential As per the thread from 2019, you most likely fitted the mid pipes upside down. Quite a few people have done this and it can lead to fitment issues. Providing they are the correct way around, it’ll fit fine. The majority of exhausts fit the NISMO absolutely fine, so I wouldn’t really call it a struggle to find a decent fitting exhaust. Quote Link to comment Share on other sites More sharing options...
Olly350z Posted February 25, 2023 Author Share Posted February 25, 2023 @Payco do you want to chime in on this? Apparently you fitted your exhaust upside down 🙃 Quote Link to comment Share on other sites More sharing options...
davey_83 Posted February 25, 2023 Share Posted February 25, 2023 (edited) Nice work on fitting the exhaust, been years since actually stood up to fit a system - axle stand life. Any pics of the tips now you've brought them out a touch? These are fairly quiet on the 350z so would make sense they're the same on the 370z. I absolutely wouldn't look to cut out the resonators on the system, warranty void plus you'll gain volume and most likely loose tone. The below are what I would be looking to get to increase noise while maintaining tone. https://www.torqen.uk/nissan/370z/exhausts/test-pipes/19156-370z-torqen-helmz-resonated-test-pipes-trq-vqhr-helmz.html 1 hour ago, Olly350z said: @Payco do you want to chime in on this? Apparently you fitted your exhaust upside down 🙃 🍿 Edited February 25, 2023 by davey_83 Quote Link to comment Share on other sites More sharing options...
GranTurismoEra Posted February 25, 2023 Share Posted February 25, 2023 It is an OEM plus type exhaust. Can probably get longer custom tips to make up the distance. As they say in London. "You guys are moving mad". 1 1 Quote Link to comment Share on other sites More sharing options...
pintopete58 Posted February 25, 2023 Share Posted February 25, 2023 Thank you Quote Link to comment Share on other sites More sharing options...
