Terence Posted November 14, 2022 Share Posted November 14, 2022 Hi I have a supercharged 350z Vortech .When fitted 418 whip it is know 354whlp. The cat is not blocked .Horsham developments have visual checked the supercharger and appears ok.Any ideas. cheers Terry Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted November 14, 2022 Share Posted November 14, 2022 Lost compression ? Quote Link to comment Share on other sites More sharing options...
Terence Posted November 14, 2022 Author Share Posted November 14, 2022 Engine Is fine Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted November 14, 2022 Share Posted November 14, 2022 Perhaps it needs more than a visual check the boys at horsham really know there stuff i would say horsham would be your best bet, good luck Quote Link to comment Share on other sites More sharing options...
Terence Posted November 14, 2022 Author Share Posted November 14, 2022 Cheers Quote Link to comment Share on other sites More sharing options...
polaris Posted November 14, 2022 Share Posted November 14, 2022 (edited) 5 hours ago, Terence said: Hi I have a supercharged 350z Vortech .When fitted 418 whip it is know 354whlp. The cat is not blocked .Horsham developments have visual checked the supercharger and appears ok.Any ideas. cheers Terry I thought you couldn't run cats with forced induction? Edited November 14, 2022 by polaris Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 14, 2022 Share Posted November 14, 2022 Dyno runs and conditions have to fairly identical to compare results. What tune did you get? Up Rev? Loss of Boost perhaps? PS: Sorry missed this bit: Cat is blocked. Quote Link to comment Share on other sites More sharing options...
Terence Posted November 15, 2022 Author Share Posted November 15, 2022 Thanks for reply Horsham have done several dyno tests . Supercharger showing same boost no obvious engine problems supercharger pressure tested ok no leaks, Test pipes fitted still 354whip . The only thing there thinking is a blockage in the back box. I have a Stillen cat back system fitted. My next step is to dyno with back box removed what do you think any ideas? Cheers Terry Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 15, 2022 Share Posted November 15, 2022 2 hours ago, Terence said: what do you think any ideas? Yes, simples, reach out to Horsham and give them the car and just ask them to fix it. They know the car much better than any of us. Quote Link to comment Share on other sites More sharing options...
Terence Posted November 15, 2022 Author Share Posted November 15, 2022 Cheers I’m going to take it back after Christmas thanks again Terry Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 15, 2022 Share Posted November 15, 2022 2 minutes ago, Terence said: Cheers I’m going to take it back after Christmas thanks again Terry Be sure to let us know how you get on and if the smile has returned. Quote Link to comment Share on other sites More sharing options...
Terence Posted November 16, 2022 Author Share Posted November 16, 2022 Will do cheers Quote Link to comment Share on other sites More sharing options...
Terence Posted May 20, 2023 Author Share Posted May 20, 2023 Horsham are still scratching their heads they say it might be the supercharger but pressure seems ok and no leaks. I could send back to Vortech for checking but this will cost. Is there anywhere in the uk who can check Vortech and rebuild if needed. Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 21, 2023 Share Posted May 21, 2023 So Horsham did both the 418 and the 354 dyno runs, correct? Are Horsham saying there is def something wrong with it? What boost are you running? What size pulley? What I’m getting at is this is lacking in details and Horsham know their stuff, so I’m surprised if they can’t fix it or give you a hint as to where to go next. Quote Link to comment Share on other sites More sharing options...
