2003 350Z just stopped running
spxntaneous_Z
On 25/09/2022 at 12:34, Stewal said:
This is the link. It seems the red led on the dash top is the key.
https://youtu.be/YHJ8JQKtdtE
I would also check the fuel pump and ignition relays and the microswitch on the clutch pedal.
Regarding the immobilizer, that’s not the problem. I realized that if the immobilizer was the problem, the fuel pump would not be priming when the ignition is on. It is priming the way it should if it were running.
