Swissh Posted September 11, 2022 Share Posted September 11, 2022 (edited) Hello, I did this mod a while back to get a raspberry pi to stay on the screen whilst driving as i had set up android auto on it. It worked fine during testing with the car parked, then when I thought I was good to go, the car cut the video feed for safety. This is a safety feature to stop people being distracted whilst driving but i wanted to use everything androidauto has to offer. After some digging around in the wiring diagrams I found what I needed to do. This is for cars with the built in Nav system. Went through the service manuals HERE and found out what needs to happen, this plus a G37 video on youtube doing the same thing but totally different cables. HERE I've attached pictures if anyone is interested in doing the same. Ignore the colour codes on the manual they don't match my Nismo 2016 but the pin layout is the same. You have to cut one cable and earth it then remove 1 pin from a connector then everything works whilst in motion. PIN OUT FOR THE CONNECTOR THE CONNECTOR AND MY EARTHING SOLUTION EARTH AND REMOVED PIN LOCATIONS The blue wire is the motion detector, the purple wire is the parking brake. Disconnect the motion detector, ground the parking brake sensor wire and DONE. This does not affect the parking brake sensor on the dash, only for the media player. Edited September 11, 2022 by Swissh Changed title to show 370z Nav Quote Link to comment Share on other sites More sharing options...
Swissh Posted September 11, 2022 Author Share Posted September 11, 2022 Whoops, i have totally messed up and posted in the wrong section, this is for 370z. Sorry, hopefully mods can move the post? Quote Link to comment Share on other sites More sharing options...
