Re Enable VDC & ABS
Osakakev
Hi,
When I imported my 350z the traction control and ABS were disabled.
I'm trying to re enable these but need a bit of help please!!
The ABS fuse was snipped so replaced this thanks to
zmanalex. The ABS light has been blanked out on the dash so I assume this is now working.
I assumed the gyroscope was disconnected but it appears not... picture attached. The VDS button is also very loose and can be physically pushed in! Is there another way of disconnecting it from behind the dash?
Cheers
