galaxyg Posted June 23, 2022 Share Posted June 23, 2022 The garage near me needs to source one to fit my car. They've found a few options and are not sure which is correct. £60-£120 so far. I thought I'd help them out by asking here. Mine is a 2005 350Z. Quote Link to comment Share on other sites More sharing options...
Coz@TORQEN Posted June 23, 2022 Share Posted June 23, 2022 Hi, We should have some in stock. Is it bank 1 or 2 which you're looking for? Bank 1 being driver side, bank 2 is passenger. Quote Link to comment Share on other sites More sharing options...
galaxyg Posted June 23, 2022 Author Share Posted June 23, 2022 Thanks. Bank1 or 2 - That I don't know. Is there any way to tell beyond a garage opening it up? I'm not very handy. Quote Link to comment Share on other sites More sharing options...
mr v6 Posted June 23, 2022 Share Posted June 23, 2022 Their diagnostic machine should have stated which bank. The sensors are different too, one is angled, the other is straight. Can't remember which is for which bank though. Quote Link to comment Share on other sites More sharing options...
Coz@TORQEN Posted June 23, 2022 Share Posted June 23, 2022 39 minutes ago, galaxyg said: Thanks. Bank1 or 2 - That I don't know. Is there any way to tell beyond a garage opening it up? I'm not very handy. If you have a photo of the sensor, I can determine which bank it is from that or alternatively, see which side the sensor is removed from - as mentioned Bank 1 is driver side, bank 2 is passenger side. How do the garage know you need a new sensor? If it's via reading fault codes, the code says which bank is needed. If they physically inspected the sensors, they would know which bank it is depending on which side of the vehicle they removed it from. The bank 1 sensor is straight sensor, bank 2 is slightly angled which should also help determine which one if it's already removed from the car. Quote Link to comment Share on other sites More sharing options...
galaxyg Posted June 23, 2022 Author Share Posted June 23, 2022 They were reading a fault code on their machine, not inspecting the car as there wasn't time at the time. The diagnostic confirmed what the Foxwell machine I'd plugged in earlier had said. The ABS Stuff seems to be a red herring, caused down the line by the Cam sensor. Currently the fault is cleared though in another thread I've been advised it'll be back after 3 cold-hot-cold cycles. Foxwell results are below, if that tells anything about the bank. Quote Link to comment Share on other sites More sharing options...
Coz@TORQEN Posted June 23, 2022 Share Posted June 23, 2022 -B1 will mean bank 1 so this is the one you need: https://www.torqen.uk/nissan/350z/engine/electronics/1024-350z-nissan-oem-camshaft-sensor-rh-23731-6j90b.html We have one in stock so can get it sent out tomorrow if you'd like to order it (the couriers have already picked up for today). 1 Quote Link to comment Share on other sites More sharing options...
galaxyg Posted June 24, 2022 Author Share Posted June 24, 2022 16 hours ago, Coz@TORQEN said: -B1 will mean bank 1 so this is the one you need: https://www.torqen.uk/nissan/350z/engine/electronics/1024-350z-nissan-oem-camshaft-sensor-rh-23731-6j90b.html We have one in stock so can get it sent out tomorrow if you'd like to order it (the couriers have already picked up for today). Thanks. Just checking the garage are happy to fit, then will order. 1 Quote Link to comment Share on other sites More sharing options...
galaxyg Posted July 1, 2022 Author Share Posted July 1, 2022 On 23/06/2022 at 16:38, Coz@TORQEN said: -B1 will mean bank 1 so this is the one you need: https://www.torqen.uk/nissan/350z/engine/electronics/1024-350z-nissan-oem-camshaft-sensor-rh-23731-6j90b.html We have one in stock so can get it sent out tomorrow if you'd like to order it (the couriers have already picked up for today). Finally garage's guy is back from Covid. No more than an hour to fit they say, so I've now ordered the part on the link above, a few mins ago. Thanks again! Quote Link to comment Share on other sites More sharing options...
Coz@TORQEN Posted July 1, 2022 Share Posted July 1, 2022 1 hour ago, galaxyg said: Finally garage's guy is back from Covid. No more than an hour to fit they say, so I've now ordered the part on the link above, a few mins ago. Thanks again! Perfect, thank you for your order. We've got it packed up so it'll be sent out today for you. Quote Link to comment Share on other sites More sharing options...
