shifty350 Posted June 8, 2022 Share Posted June 8, 2022 I installed some hel braided lines on the front over the weekend and wondered if I needed to also bleed the rears or can I get away with just doing the fronts? Cheers Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 9, 2022 Share Posted June 9, 2022 Providing you did not let the reservoir run dry then bleeding the fronts should be good, however I would recommend bleeding the rears as well and replenish all the old fluid with fresh high temperature fluid. 1 Quote Link to comment Share on other sites More sharing options...
