Tomato Posted May 28, 2022 Share Posted May 28, 2022 So have had fitted a sports cat and new exhaust (which sounds great 😁). The car has had oil and filters changed and sparks changed at the same time. Since having the exhaust changed, the car occasionally has a lag when accelerating, not all the all the time, have noticed in 2nd and 3rd gear. It seems to be when you are off the power for a few seconds and then accelerate, feel like there is a little pause and then it goes. Its more annoying than anything else. It did not think changing the exhaust would make any difference and wondering if I need to reset anything for the car to realise the exhaust gases flow more easily. Its a HR with revup mapping. Any thoughts. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 28, 2022 Share Posted May 28, 2022 If you have fitted the correct plugs and they are gapped properly, and hooked up to your coils properly, then I think that you may need a tweak to your Uprev to fix your issue if it does not self learn. Quote Link to comment Share on other sites More sharing options...
Tomato Posted May 28, 2022 Author Share Posted May 28, 2022 Thanks, I did wonder if the ECU needed to relearn, is there a simple way to clear it learnings/history, I remember doing it on an 350 SLK and it transformed the car 🤣 Any idea how long it takes to relearn? If it does need a map, may wait as thinking of changing the intake a few other bits on top, it would need a remap then. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 28, 2022 Share Posted May 28, 2022 Changing your intakes away from the stock OEM air boxes will be detrimental to your performance. I have yet to find an after market intake/s which improve on OEM. 1 Quote Link to comment Share on other sites More sharing options...
Tomato Posted May 28, 2022 Author Share Posted May 28, 2022 Thanks for the tip 👍 Quote Link to comment Share on other sites More sharing options...
