help, 3 lights and 3 engine codes
elliothudson123
ok so i got a cel a traction control light and slip light then a couple days later car started running really lumpy- probably misfire, scanned for codes and got
P0102 - mass or volume air flow circuit low imput
P0350 - ignition coil primary/secondary circuit
P0113 - intake air temperature circuit high imput
ive taken the coil packs out and tested them and all of them are above 1.5 ohms resistance accept 2 witch were only a tiny bit below, my spark plugs are also really worn but tested them with the multimeter too and there algood.
