ZMANALEX Posted April 18, 2022 Share Posted April 18, 2022 Just removed from my own car as now going Sequential. As new condition as you would expect after 6 x track sessions tail end of last year. An absolutely brilliant short shifter and with out doubt the best on the market. Your shifts will be extremely slick and precise and so much quicker Very easy to install and comes with full illustrated easy to follow installation instructions. Fits all 6 speed manual 350Z 2003 - 2009. #SOLD# Each shifter comes with direct-fit kit to install in Nissan 350Z / Infinity G35 G37 40% shorter throw between gears Shortened gear change pattern allows to switch between gears much much faster! Shifter is mounted directly to gearbox as opposed to OEM shifter which is mounted to the gearbox bridal, this gives much stiffer and better shifting experience Longer handle allows for shifter to sit closer to wheel, therefore giving better performance in race application Can be used with OEM gearbox/engine mounts Original H patter remains, but it is much shorter and precise. Reverse / 5/6 gears can be locked using included screws Interior plastics can be installed with little to no modifications High quality materials guarantee problem free shifting World wide warranty for every purchase 1 Quote Link to comment Share on other sites More sharing options...
Ry-B Posted April 18, 2022 Share Posted April 18, 2022 PM sent Quote Link to comment Share on other sites More sharing options...
prodrive11 Posted April 20, 2022 Share Posted April 20, 2022 (edited) Why so late... Assume you've got spare cd009 to go for cheap now ? Btw. quaife or samsonas ? 😉 Edited April 20, 2022 by prodrive11 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 8, 2022 Author Share Posted May 8, 2022 SOLD Quote Link to comment Share on other sites More sharing options...
da.murf Posted November 24, 2022 Share Posted November 24, 2022 don't suppose you ever had more of these sitting about? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 24, 2022 Author Share Posted November 24, 2022 Afraid not mate, sorry. Quote Link to comment Share on other sites More sharing options...
da.murf Posted November 27, 2022 Share Posted November 27, 2022 On 24/11/2022 at 15:00, ZMANALEX said: Afraid not mate, sorry. Aw worth a shot. I managed to pick one up through Black Friday sales on their site. can you give me any first hand insight into them? Make a nice difference etc? Thx Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 27, 2022 Author Share Posted November 27, 2022 As per my first post: However it is critical that it is set up properly, other wise gear shifts can be baulky. Each shifter comes with direct-fit kit to install in Nissan 350Z / Infinity G35 G37 40% shorter throw between gears Shortened gear change pattern allows to switch between gears much much faster! Shifter is mounted directly to gearbox as opposed to OEM shifter which is mounted to the gearbox bridal, this gives much stiffer and better shifting experience Longer handle allows for shifter to sit closer to wheel, therefore giving better performance in race application Can be used with OEM gearbox/engine mounts Original H patter remains, but it is much shorter and precise. Reverse / 5/6 gears can be locked using included screws Interior plastics can be installed with little to no modifications High quality materials guarantee problem free shifting World wide warranty for every purchase Quote Link to comment Share on other sites More sharing options...
da.murf Posted November 28, 2022 Share Posted November 28, 2022 14 hours ago, ZMANALEX said: As per my first post: However it is critical that it is set up properly, other wise gear shifts can be baulky. Each shifter comes with direct-fit kit to install in Nissan 350Z / Infinity G35 G37 40% shorter throw between gears Shortened gear change pattern allows to switch between gears much much faster! Shifter is mounted directly to gearbox as opposed to OEM shifter which is mounted to the gearbox bridal, this gives much stiffer and better shifting experience Longer handle allows for shifter to sit closer to wheel, therefore giving better performance in race application Can be used with OEM gearbox/engine mounts Original H patter remains, but it is much shorter and precise. Reverse / 5/6 gears can be locked using included screws Interior plastics can be installed with little to no modifications High quality materials guarantee problem free shifting World wide warranty for every purchase ok cool, any hints or experience on best was to set up? I'll be following the instructions, but anything else helpful to know? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 14, 2023 Author Share Posted March 14, 2023 SOLD Quote Link to comment Share on other sites More sharing options...
harrison140 Posted November 21, 2024 Share Posted November 21, 2024 I know this is quite old now but how did it go with the sequential and what make did you use. Quote Link to comment Share on other sites More sharing options...
