Front bumper stuck
polaris
Trying to get at the screen wash reservoirs but having a major issue with my front bumper. While using a 10mm, the screws turn with the mounting clips causing damage to the plastic. It's only the 2 furthest on each side which are stuck which I assume it because of rust/corrosion. Any ideas on how I can free these up without damaging my bumper? The screws in the middle came away fine with a bit of WD40 through the top but I can't get at any of the others.
Soak in WD40 overnight.
Hold the "mounting clip" with a set of vise grips, otherwise you will rip the bumper when you turn the bolt.
The head of the bolt will probably snap off, but no drama as plenty new bolts and clips in stock.
