Hoss Posted March 26, 2022 Share Posted March 26, 2022 Hi guys, now getting the Zed out from hibernation to take for mot. However I have noticed that the 2 side windows both drop when opening the doors but do not return back up when I shut them. Is this likely to be something stuck and needing lubricating ( have fired Mecoil into locks with no success) Any half or info greatly appreciated Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted March 26, 2022 Share Posted March 26, 2022 (edited) I think there's a microswitch that controls the window action in the door jamb ... try operating this with the door open Edited March 26, 2022 by ATTAK Z Quote Link to comment Share on other sites More sharing options...
Roscoe Posted March 26, 2022 Share Posted March 26, 2022 On 26/03/2022 at 13:30, ATTAK Z said: I think there's a microswitch that controls the window action in the door jamb ... try operating this with the door open Expand This ^^ sometimes it’s worth taking the micro switch off as it’s earthed through the car and giving the mating surfaces a clean 👍🏼 Quote Link to comment Share on other sites More sharing options...
Hoss Posted March 26, 2022 Author Share Posted March 26, 2022 Thanks both, will give it a try Quote Link to comment Share on other sites More sharing options...
Umster Posted March 27, 2022 Share Posted March 27, 2022 Windows need resetting, I had this issue when the battery went flat and needed a jump start. Can't remember off the top of my head but basically need to hold the window up switch for 5 seconds after the window is at its highest point. Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted March 27, 2022 Share Posted March 27, 2022 Yeah i'd try a window reset as above, mine did this after disconnecting the battery to change the steering wheel. Every time I opened the door it would drop 10mm and not go back up. 1. Push the ignition switch to the ON position.2. Close the door.3. Open the window completely by operating the power window switch.4. Pull the power window switch and hold it to close the window, and then hold the switch more than 3 seconds after the window is closed completely.5. Release the power window switch. Operate the window by the automatic function to confirm the initialization is complete.6. Perform steps 2 through 5 above for other window Quote Link to comment Share on other sites More sharing options...
Hoss Posted March 27, 2022 Author Share Posted March 27, 2022 Done the windows reset and working perfectly Thank you very much gentlemen 2 Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted March 27, 2022 Share Posted March 27, 2022 No worries, glad its all sorted with a simple fix Quote Link to comment Share on other sites More sharing options...
Umster Posted March 27, 2022 Share Posted March 27, 2022 The best fixes are the ones that are free and take 2 mins. Hope you get to enjoy the Z this summer! Quote Link to comment Share on other sites More sharing options...
Loadmaster Posted March 30, 2022 Share Posted March 30, 2022 On 27/03/2022 at 06:56, Willsy1980 said: Yeah i'd try a window reset as above, mine did this after disconnecting the battery to change the steering wheel. Every time I opened the door it would drop 10mm and not go back up. 1. Push the ignition switch to the ON position.2. Close the door.3. Open the window completely by operating the power window switch.4. Pull the power window switch and hold it to close the window, and then hold the switch more than 3 seconds after the window is closed completely.5. Release the power window switch. Operate the window by the automatic function to confirm the initialization is complete.6. Perform steps 2 through 5 above for other window Expand I was aware that there was a procedure but didn't know what the steps were. Thanks for posting this, I'm going to cut/paste/print and put it in the glovebox, just in case! 1 Quote Link to comment Share on other sites More sharing options...
EvansJD2112 Posted March 30, 2022 Share Posted March 30, 2022 I had similar. ended up going back to Nissan in warranty Quote Link to comment Share on other sites More sharing options...
pintopete58 Posted March 31, 2022 Share Posted March 31, 2022 Hi guys what happens when you have push button start you can't turn ignition on Quote Link to comment Share on other sites More sharing options...
Matay20 Posted April 1, 2022 Share Posted April 1, 2022 Just press the ignition button once without pressing the clutch or brake to turn it on. 1 Quote Link to comment Share on other sites More sharing options...
Matay20 Posted April 1, 2022 Share Posted April 1, 2022 On 01/04/2022 at 06:49, Matay20 said: Just press the ignition button once without pressing the clutch or brake to turn it on. Expand I meant start button. search YouTube as there is a good video, my trickle charger came off and I had the same issue but it’s quick and easy to resolve. Quote Link to comment Share on other sites More sharing options...
pintopete58 Posted April 1, 2022 Share Posted April 1, 2022 Cheers bud . Your all full of information great thanks 1 Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted April 1, 2022 Share Posted April 1, 2022 On 01/04/2022 at 06:49, Matay20 said: Just press the ignition button once without pressing the clutch or brake to turn it on. Expand Exactly this, if your foot is not on the clutch, it won't start and just turns on Aux power Quote Link to comment Share on other sites More sharing options...
