Cobra Sports Exhaust - SOLD
RobPhoboS
SOLD TO:
timww1966
(minus DD's so will post them up for sale separately)
I've just changed my exhaust, so this is up for sale now.
Ideally someone will buy the lot, and then will have a choice of resonated, or non-resonated, as well as having the 2.5" Decibel Devils for track days.
The tips quickly come off (10mm bolts), and the DD's are inserted, will help reduce several db's for track days.
£380 for the lot (postage tbc)
(New they're £610 non res, £650 res. Res pipe £250 iirc, DD's £60 ea)
I'm more than happy to take extra photos if needed, I just gave the pipes a quick clean up this afternoon and didn't spot anything bad.
No weld repairs or holes.
I'm based near J8 - M25 (about 10 mins from that), so ideally you'd come and collect.
I do have a box from the new exhaust, and it may well fit inside, I'll try to find out today.
Don't forget, you'll need 2x new 3" gaskets.
Edited by RobPhoboS
3 hours ago, timww1966 said:
Hi, What model was this fitted to? Daughter has a VQ35HR and the DE and prior aftermarket exhausts don't fit :(
My car is a 2004.
I'm not sure what the stock HR y-pipe is like, as that's what this would connect to.
Assuming that the end of the Y-pipe is a 2 bolt flange, 3" and centrally located, I imagine it should fit.
However, I'd recommend you do some research first to double check :thumbs:
  • RobPhoboS changed the title to Cobra Sports Exhaust - SOLD
