Oscarsnz1 Posted February 25, 2022 Share Posted February 25, 2022 I’m having a hard time. So I bought my 350z about a month ago. Got it for a good deal knowing it had a few issues one being the A/C and heat does not work and my needles on the cluster don’t move. The guy said everything worked before he installed the hydro he thought maybe a fuse or a ground was left undone but, I pulled the head unit and the navigation and everything looks good. I’ve check all 3 fuse boxes all the fuses look fine. I have also read that the cable wire on the climate control amp goes bad so I ordered on and replaced it and nothing . Do you guys think I should look into maybe replacing the whole amp? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 25, 2022 Share Posted February 25, 2022 Have you checked the temperature gauge sender unit which is on the rear coolant pipe behind the engine. ? Air con amps, gauges, and temp gauge sender units are all in stock if required. Just drop me a PM if I can help further. Quote Link to comment Share on other sites More sharing options...
