Supercharger upgrade
secretstar07979
Hello
A bit of advice needed please
I am running the GTM 1.5 supercharger set up.  With a smaller pulley the last dyno was 491bhp. My question is what options do I have for more power? I don't really want to go down the TT route due to the expense. I was thinking a larger supercharger.  Due to the current set up would it be a case of installing a larger supercharger capable of creating more boost? Or will I need to start from scratch with a new set up?
As per my reply on your other post, unless you build the motor, I'd say don't go any higher.
I know they get loads more power in the USA but a lot of that is down to using E85 (an easy extra 100hp), and if you're on the USA Z groups, you'll also see lots of blown motor posts, so they're clearly pushing the envelope, and past it.
