Mitchelln Posted January 29, 2022 Share Posted January 29, 2022 Hi all, Can anyone here say the price quoted for the work is reasonable or being ripped off. https://uk.ivhc.com/glynhopkin/9525322/5820860AV57ZNR2912022 Link above is for the inspection carried out half way through is the repairs needed and costs One is the lower sump needing repair at around £500 The other is drive belt at around £130. Thanks for any input here. Quote Link to comment Share on other sites More sharing options...
Azurez33 Posted January 29, 2022 Share Posted January 29, 2022 Definitely way too much- sump doesn’t look dreadful but you could replace it to be safe- Defintely wouldn’t cost that much at my garage, should also do an oil and filter. Is that for the one aux belt or both? Problem is Nissans labour is probably ridiculously high due to main dealer and them being scarce 😂 Quote Link to comment Share on other sites More sharing options...
Azurez33 Posted January 29, 2022 Share Posted January 29, 2022 Did see drive shaft seal was there too, couldn’t see a quote for that? Quote Link to comment Share on other sites More sharing options...
Mitchelln Posted January 29, 2022 Author Share Posted January 29, 2022 Cheers for responding, this is all they have me on the details on what needs doing everything they said was all in the green / ok. I take it garage instead see what they say for a price. Quote Link to comment Share on other sites More sharing options...
Mitchelln Posted January 29, 2022 Author Share Posted January 29, 2022 1 hour ago, Azurez33 said: Definitely way too much- sump doesn’t look dreadful but you could replace it to be safe- Defintely wouldn’t cost that much at my garage, should also do an oil and filter. Is that for the one aux belt or both? Problem is Nissans labour is probably ridiculously high due to main dealer and them being scarce 😂 Just for six belt was around £130 that was all advised to have done or needed doing. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 29, 2022 Share Posted January 29, 2022 Belt costs £40.00 + 5 minutes to fit. Sump pans are £110.00 + 1 hours labour maximum. Oil and filter change would be £60.00 for the parts and labour would be included with the sump pan swop out. Hope this helps. 1 Quote Link to comment Share on other sites More sharing options...
