Can anyone tell me what pipe this is please??
Rob350
So changing the belts on my 04 Z and tapped this metal coolant pipe, its proper crusty so cracked straight away. It goes from the oil filter across and up behind the alternator.
Does anyone know what it's called?? Or where to find part number etc so I can buy a replacment.
Cheers guys.
@Adrian@TORQEN
Thanks for the diagram but the pipe I need isnt on there, I believe it's a oil cooler/warmer pipe?? Its definatly got coolant in it.
It connects at the oil filter housing pic1, goes from rubber to the metal pipe I need pic 2, then the metal pipe runs under all the pulleys, then under the aircon condenser, then up between the engine and condenser and connects back to a rubber hose beneath the pipe you have for sale.
Edited by Rob350
Should show on this diagram instead: https://nissan.7zap.com/en/er/z/z33/1+509+701/c/213/
Looks like it's part number '14053-AM80A'
We have it listed here if that is the one you're looking for: https://www.torqen.uk/nissan/350z/cooling/oil-coolers/23568-350z-de-nissan-oem-oil-cooler-hard-pipe-front-lh-14053-am80a.html (Not in stock but most likely 1-2 weeks or so to get one here).
