Phils_Reading Posted December 31, 2021 Share Posted December 31, 2021 Does anyone have any suggestions on what might be at fault. I've got an 05 Roadster and both windows have completely stopped working. They won't work from either drivers or passengers switches, or even auto dip as you open the doors. Since noticing the problem a week ago they both did work again using the drivers side switch but only the once and now its back to nothing. I've checked the fuses in the cabin fuse box and they are all fine. Checked its not just the window lock button pressed. I've taken all the drivers door apart and tried the reset button on the motor but as they wont move at all I obviously can't properly try the reset procedure. I haven't tried opening the roof yet to see if that brings the windows down as the weathers crap atm and don't really want to be stuck with the windows down if it worked. Would one faulty motor stop the other window from working? or would the master switch on the drivers door stop the passenger side working if it was faulty? Any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 31, 2021 Share Posted December 31, 2021 Best to get your multi meter out to remove the guess work. Quote Link to comment Share on other sites More sharing options...
