miller_350 Posted December 28, 2021 Share Posted December 28, 2021 Hi, My imported 350 didn't come with a space saver and sods law I'm going to have a puncture at some point. My car has brembos and currently running 275/35/Y19 on the rears. My speedo is out more than normal so I use a GPS one (not sure if this is resolvable with current alloys). Will a standard space saver fit? Two on eBay from 2015 and 2017 (my car is 2016 rev up) I'm not bothered about saving weight or bigger boot so space saver seems less hassle than tyre weld. Cheers Quote Link to comment Share on other sites More sharing options...
davey_83 Posted December 28, 2021 Share Posted December 28, 2021 Hi, a space saver will clear the brakes on the rear however not the fronts. The gig normally is to use the space saver on the rear in chase of puncher. If you get a puncher up front, you'd swap a rear for a space saver then put the rear wheel up front to get you home or to a garage. 1 Quote Link to comment Share on other sites More sharing options...
miller_350 Posted December 28, 2021 Author Share Posted December 28, 2021 Great thank you! So any 350z space saver will fit on the rears? Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted December 30, 2021 Share Posted December 30, 2021 On 28/12/2021 at 21:15, davey_83 said: Hi, a space saver will clear the brakes on the rear however not the fronts. The gig normally is to use the space saver on the rear in chase of puncher. If you get a puncher up front, you'd swap a rear for a space saver then put the rear wheel up front to get you home or to a garage. I never knew that. I'd be the one cursing that it didn't fit the front and not think to swap it with the rear. Quote Link to comment Share on other sites More sharing options...
Jack94 Posted December 30, 2021 Share Posted December 30, 2021 Surely that can't be right, terrible design if the OEM space saver doesn't clear the OEM brembo brake callipers on the front With LMGT4's (which were a factory option right?) then wouldn't the 275 width tyre from the rear cause rubbing on the front? 1 Quote Link to comment Share on other sites More sharing options...
Umster Posted December 30, 2021 Share Posted December 30, 2021 Are the wheel studs the same size front and rear? The only drawback for RWD cars is the logistics of a staggered setup. Quote Link to comment Share on other sites More sharing options...
miller_350 Posted January 4, 2022 Author Share Posted January 4, 2022 Thank you all. Does anyone know which one I need to clear the brembos? Door card says T145/80D17 but not sure car originally came with brembos. I can find two on eBay, one is above and other is T155/80R17 100M. I assume bigger is better (as I have 19inch wheels) but want to make sure it fits in the boot as well. cheers Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted January 5, 2022 Share Posted January 5, 2022 On 30/12/2021 at 14:46, Jack94 said: Surely that can't be right, terrible design if the OEM space saver doesn't clear the OEM brembo brake callipers on the front With LMGT4's (which were a factory option right?) then wouldn't the 275 width tyre from the rear cause rubbing on the front? 1st thing ive done is remove the space saver and take it to the local tip save some weight, the saved fuel will pay for a roadside assistance/tyre replacement if ever needed. But yeah clearance would be a massive issue, even more so on the 370 no way in hell would the rears on the Nismo fit the front, first corner would rip the wing off... To answer Miller, I dont think any 17inch Spacesaver clears the front Brembos on the 350. Quote Link to comment Share on other sites More sharing options...
miller_350 Posted January 7, 2022 Author Share Posted January 7, 2022 Cheers I'm not really bothered about saving weight just want the least hassle if I get a puncture. Do you know the reason for two different 17 inch space saver sizes if they neither won't fit over the brembos at the front? Cheers Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted January 8, 2022 Share Posted January 8, 2022 Only difference is the tyre width on them, internal rim size is the same. One was probably from the early DE and the larger supplied with the Rev up and HR. @ZMANALEX may know more on the specifics of them, and even supply one for you 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 8, 2022 Share Posted January 8, 2022 As @Willsy1980 has said, one is for the early DE and the other for the Rev up and the HR and both wheels are the same dimensions. Both will fit your application and clear the Brembos without spacers. 2 Quote Link to comment Share on other sites More sharing options...
Osakakev Posted January 9, 2022 Share Posted January 9, 2022 Great, thank you both! I will go with the smaller one as this is what's on the door card Quote Link to comment Share on other sites More sharing options...
