Rob350 Posted December 27, 2021 Share Posted December 27, 2021 So my DE is using oil like 70% of them out there. Though mine is pretty thirsty at 700ml/1k with 5/30 Anyway.. I'm going to go 10/40 now.. The question is.. I have always used castrol edge in my cars.. I'm sure I've read a thread on here were someone said they used a fuchs oil it was fine, then went castrol edge and it started using it, then back to fuchs and was fine again. I have read even with other cars that some castrol oils are thinner/burn more than other oils even though the the same weights have been used. Can anyone tell me from experience what oils burns less than Castrol?? I'm sure the thread said titan fuchs, theres a few different titan fuchs to choose from though. Any experiences or knowledge would be great. Thanks.. Quote Link to comment Share on other sites More sharing options...
Rob350 Posted December 28, 2021 Author Share Posted December 28, 2021 Found the thread... Quote Link to comment Share on other sites More sharing options...
nozb2k Posted January 2, 2022 Share Posted January 2, 2022 Have you pulled your coilpacks and checked for oil? Could be the culprit for your oil use, especially on the DE. I'd even swap or clean your PCV valve. Quote Link to comment Share on other sites More sharing options...
Deemanon Posted February 19, 2022 Share Posted February 19, 2022 I've been scouting the internet to find an answer and it seem to boil to the same issue, using the wrong oil brand... My 06 DE just had its service, I've been checking the oil level religiously, I've found i use about 1L per 100 miles, I've done about 300 miles and the oil seems mega dark, should I try a different oil or just head out for an engine rebuild? 104k miles on clock using 5w-40 Quote Link to comment Share on other sites More sharing options...
Ekona Posted February 20, 2022 Share Posted February 20, 2022 1L every 100mi is pretty much the sign of a dead engine, I’d get a new engine sooner rather than later. That’s an horrendous amount of oil to be using. Quote Link to comment Share on other sites More sharing options...
Deemanon Posted February 20, 2022 Share Posted February 20, 2022 1 minute ago, Ekona said: 1L every 100mi is pretty much the sign of a dead engine, I’d get a new engine sooner rather than later. That’s an horrendous amount of oil to be using. I've had this car for 14 days, just spoke to previous owner, he's claiming the car never had an issue like that and he's not willing to cooperate and I'm on verge of crying now Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 20, 2022 Share Posted February 20, 2022 1lt per 100 miles is crazy. if burning that amount of oil you would have an excessive amount of blue smoke coming out the exhaust depending on what cats you are running. Check for oil leaks and if okay I would change the oil and filter with the correct oil and OEM filter. If problem still persists, then time for a transplant I am afraid. Quote Link to comment Share on other sites More sharing options...
Ekona Posted February 20, 2022 Share Posted February 20, 2022 3 hours ago, Deemanon said: I've had this car for 14 days, just spoke to previous owner, he's claiming the car never had an issue like that and he's not willing to cooperate and I'm on verge of crying now Ouch, that’s an expensive lesson to learn, sorry dude Quote Link to comment Share on other sites More sharing options...
Deemanon Posted February 20, 2022 Share Posted February 20, 2022 1 hour ago, Ekona said: Ouch, that’s an expensive lesson to learn, sorry dude I'm gonna try a thicker oil soon and if that don't work I'll have to find a different way to fix it Quote Link to comment Share on other sites More sharing options...
Ekona Posted February 20, 2022 Share Posted February 20, 2022 Thicker oil won’t do you any good at all mate if it’s using that much, trust me if it’s as bad as you say it is then that’s terminal. Is it showing blue smoke as Alex mentioned? Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted February 20, 2022 Share Posted February 20, 2022 Unless there's excessive blue smoke, the only thing I can add to Alex's advice is to make absolutely sure you're reading the oil level accurately - it's remarkably easy to get it wrong on the DE; cold engine, left of level ground overnight, no excessive dipping. To get a completely accurate view, drain it and measure the amount coming out. If you really are using that much oil and there's no blue smoke, check for leaks first and foremost then consider changing the oil. If none of that fixes your issue then it's time to start thinking about an engine swap. Quote Link to comment Share on other sites More sharing options...
Deemanon Posted February 20, 2022 Share Posted February 20, 2022 (edited) 32 minutes ago, ilogikal1 said: Unless there's excessive blue smoke, the only thing I can add to Alex's advice is to make absolutely sure you're reading the oil level accurately - it's remarkably easy to get it wrong on the DE; cold engine, left of level ground overnight, no excessive dipping. To get a completely accurate view, drain it and measure the amount coming out. If you really are using that much oil and there's no blue smoke, check for leaks first and foremost then consider changing the oil. If none of that fixes your issue then it's time to start thinking about an engine swap. I'm gonna go give it a dip in a moment, it's been stood since last night (10pm) hopefully there something in there as I put 2 liters in at Chester services and got to Leeds... No blue smoke, very minimal smoke to be honest.. Smells hella bad putting foot down Any common places to check for leaks? Edited February 20, 2022 by Deemanon Quote Link to comment Share on other sites More sharing options...
Ekona Posted February 20, 2022 Share Posted February 20, 2022 Not really, anywhere and everywhere but that amount should be fairly obvious. Think you’re really going to have to drain the oil and find out exactly how much is in there, as too much oil is just as bad not enough. Quote Link to comment Share on other sites More sharing options...
