Reece9426 Posted November 13, 2021 Share Posted November 13, 2021 Hey everyone! First post on here to be kind Anyone had this problem? Seems like a knocking/rattle on the gear shifter after 4k rpm and onwards happens in all gears at the same rpm, goes away if I clutch in or hold the stick. 2014 nismo 370z. Sent a link to the youtube video below of the noise. Thanks! Quote Link to comment Share on other sites More sharing options...
davey_83 Posted November 14, 2021 Share Posted November 14, 2021 Is the gear knob tight on the spline? Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted November 14, 2021 Share Posted November 14, 2021 Does it make the noise if you are holding the shifter knob ? Could be the trim rattling in the clips or the wire clip under it for the reverse sensor thing Quote Link to comment Share on other sites More sharing options...
Reece9426 Posted November 14, 2021 Author Share Posted November 14, 2021 On 14/11/2021 at 09:41, Willsy1980 said: Does it make the noise if you are holding the shifter knob ? Could be the trim rattling in the clips or the wire clip under it for the reverse sensor thing Expand It seems to have been fixed, I pulled the rubber cover up as it was all the way down back to the top not 100% is that was the fix but no longer doing it. It did get quieter when I held onto the gear knob. See if it returns but for now it's fine. Quote Link to comment Share on other sites More sharing options...
xrb Posted September 22, 2023 Share Posted September 22, 2023 Hi, did you get the noise back? Im having the same issue on a 2016 370z, Ive torn everything down, discarted the knob, lever and all shifter mechanism, My conclusion is that its the linkage. This is my car: https://youtube.com/shorts/EiMaXkv_rZ4?feature=share And this is another video I have found were its mentioned, he changed the whole shifter mechanism so its not there, at min 12.37: https://youtu.be/TPg5nuOiH_c?si=8JG7HfcNmlJb13ql&t=757 Quote Link to comment Share on other sites More sharing options...
Dave G Posted October 24, 2023 Share Posted October 24, 2023 I can't help here I'm afraid but I have exactly the same issue. My car has done it since I bought it (at 3 years old). I've no idea what causes it either... Quote Link to comment Share on other sites More sharing options...
