SWoMP Posted October 21, 2021 Share Posted October 21, 2021 Dreaded MOT has "advised" my Cats' Heat Shields are rusting away (although Cats must still be working as emissions still compliant). Anyone know if the Heat Shields can be replaced separately? TIA Quote Link to comment Share on other sites More sharing options...
Coz@TORQEN Posted October 21, 2021 Share Posted October 21, 2021 Hi, As far as I remember the heat shields are actually part of the OEM cats, see diagram: https://nissan.7zap.com/en/er/z/z33/5+701+65535/c/208/ Your best bet would be aftermarket HFC's unless you can find a decent priced set of OE cats (they're £2k+ brand new). Then sell the OEM ones and you'd most likely end up with some profit after purchasing the HFC. We're expecting these in around 2 weeks or so: https://www.torqen.uk/nissan/350z/exhausts/high-flow-cats/62687-350z-de-z33-torqen-high-flow-cats-v2-trq-vqde-hfc-v2.html They'll pass MOT just fine, providing they're properly warmed up right before the emissions test. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 21, 2021 Share Posted October 21, 2021 No need to splash the cash on this one, just remove the heat shields and you will be golden. Quote Link to comment Share on other sites More sharing options...
RavenDW Posted November 22, 2021 Share Posted November 22, 2021 On 21/10/2021 at 13:39, SWoMP said: Dreaded MOT has "advised" my Cats' Heat Shields are rusting away (although Cats must still be working as emissions still compliant). Anyone know if the Heat Shields can be replaced separately? TIA If you haven't sorted this yet, try getting a reel of hose clamp (the same stuff as jubilee clips) to wrap around the cats. Mine were rattling and now they're strapped up the problem is solved. That is unless you want to change the cats. On 21/10/2021 at 14:52, Coz@TORQEN said: Hi, As far as I remember the heat shields are actually part of the OEM cats, see diagram: https://nissan.7zap.com/en/er/z/z33/5+701+65535/c/208/ Your best bet would be aftermarket HFC's unless you can find a decent priced set of OE cats (they're £2k+ brand new). Then sell the OEM ones and you'd most likely end up with some profit after purchasing the HFC. We're expecting these in around 2 weeks or so: https://www.torqen.uk/nissan/350z/exhausts/high-flow-cats/62687-350z-de-z33-torqen-high-flow-cats-v2-trq-vqde-hfc-v2.html They'll pass MOT just fine, providing they're properly warmed up right before the emissions test. With these, any known issues with setting off the O2 sensors? I know some necessitate spacers or remaps to avoid the fault. Quote Link to comment Share on other sites More sharing options...
SWoMP Posted November 22, 2021 Author Share Posted November 22, 2021 Thanks for the replies each. I have a pair of secondhand oem cats and looked at putting these on. However, when I looked at existing it is clear the only problem is the heat shields as the cats themselves easily pass the emission test. So, I'm going to remove the heatshields and run like that for a while, keeping the s/hand but almost new ones as backups. Incidentally, Amayama say new oem no longer available from Nissan. Quote Link to comment Share on other sites More sharing options...
Coz@TORQEN Posted November 22, 2021 Share Posted November 22, 2021 4 hours ago, RavenDW said: If you haven't sorted this yet, try getting a reel of hose clamp (the same stuff as jubilee clips) to wrap around the cats. Mine were rattling and now they're strapped up the problem is solved. That is unless you want to change the cats. With these, any known issues with setting off the O2 sensors? I know some necessitate spacers or remaps to avoid the fault. They already have extended O2 sensor bungs so rarely throw any EML from our experience. If they do, you can have it mapped out as a last resort. 1 Quote Link to comment Share on other sites More sharing options...
