05 350z - Engine problems
Arch
Hello, I have an 05 350z
Car is showing engine light, slip light, and ESP OFF light on the dash.
Cold start the car is fine idles at 1500rpm or there about.
Once it starts warming up and the revs drop down to 500-1000rpm it starts stuttering but stops once you get the revs back up.
So far we have:
- Changed all the spark plugs
- Cleaned the throttle body and MAF sensor
- Cleaned all wiring harness connections
Any ideas where to look next?
Best to hook up a code reader so that you can pull and check the fault codes.
This will give you an informed indication on where to look next.
Send me over the DFCs and I will help you with your diagnoses and I will probably have the parts in stock for a quick fix.
