Rajtastic Posted September 13, 2021 Share Posted September 13, 2021 Hey guys, Got a nice little button to turn on/off TCS by cutting out the connection to the yaw sensor (well documented solution) but weirdly my wiring doesn't seem to match anything I can see online. All the manuals seem to show this wiring: However, I don't have orange - only these wires: I can find the wire I need just by sensing for 12V (I know you can use the red/white earth to be safer but I want to use the 12v to power by button light): (switch from Air Onboard UK) Anyone ever seen this wiring before? Cheers, Raj Tastic Quote Link to comment Share on other sites More sharing options...
Rajtastic Posted September 26, 2021 Author Share Posted September 26, 2021 OK - I winged it by looking at where the orange wire goes on other people's wiring and I got it right - it's the grey wire if you want the 12V wire (only do this if you want to use the switch light - otherwise use the red/white earth to eliminate the risk of shorting anything when you do the work😞 Note : the dash-light wire from the passenger heat seat switch (white wire) should illuminate the bunny on my light to yellow when I turn on the car. However, it doesn't seem to. Either I got the wrong wire or the dash light somehow only comes on at night (which I doubt). I should probably disconnect. I'd recommend these suckers for sure - zero crimping tools to connect the wires: Wago 221 connectors Here's the switch I used: https://www.aironboard.co.uk/online/nissan-switch-n127go-bunny-burners-amber-green-on-off.html Now the switch is green when ESP is normal (i.e. engaged) but when you press it it will kill the TCS and stability control (as per the common mod people do): ESP/VDC completely off when I depress the above button: Quote Link to comment Share on other sites More sharing options...
