arcdef Posted August 27, 2021 Share Posted August 27, 2021 Hi all,  I recently replaced all the front arms with Moog parts on my 2004 350z and ever since I've noticed that the steering won't return to centre.  From the research I've done it seems there isn't a way to adjust caster so not sure how I am meant to rectify this?  Car drives straight and turn in feels good it just disconcerting that it isn't returning to centre and wasn't doing it before.  Thanks, Ash     Quote Link to comment Share on other sites More sharing options...
arcdef Posted August 27, 2021 Author Share Posted August 27, 2021 I should add, the car is on stock suspension and wheels. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 28, 2021 Share Posted August 28, 2021 I doubt it it is a castor issue, unless the fitter messed up You do not say exactly what arms you replaced. Did you get a full geo. done after fitment? If so, post up the print out. I would be looking at an issue with the new parts or a fitment issue. Check tyre pressures. Quote Link to comment Share on other sites More sharing options...
Azurez33 Posted August 28, 2021 Share Posted August 28, 2021 Literally everything Alex said, thing is aswell that youâve probably replaced items along the way such as tyres and possibly other suspension parts and things have slowly started to set in and rest causing the tracking to go out unnoticed, now youve replaced the suspension arms etc everythingâs the way it should be and itâs knocked the tracking out largely because there wasnât the tolerance it was before due to old parts Quote Link to comment Share on other sites More sharing options...
Azurez33 Posted August 28, 2021 Share Posted August 28, 2021 Unless youâve replaced the top mounts aswell with adjustable caster mounts, I donât see there being any way you could drastically adjust the caster that much the self centering  would be gone. Quote Link to comment Share on other sites More sharing options...
arcdef Posted August 29, 2021 Author Share Posted August 29, 2021 All the front arms were changed, the strut was removed but put back in as is. Can the front toe angle impact the self steering? Thanks Quote Link to comment Share on other sites More sharing options...
Azurez33 Posted August 29, 2021 Share Posted August 29, 2021 No chap only the positive castor, donât even think itâs possible to put the shocks in wrong way either Quote Link to comment Share on other sites More sharing options...
Azurez33 Posted August 29, 2021 Share Posted August 29, 2021 Of your toe is excessively out, itâll feel like harsh grabbing and is incredibly noticeable, however if the toe in fairly out itâll start wearing either edge dependant on where the trackings out, Quote Link to comment Share on other sites More sharing options...
G1en Posted August 30, 2021 Share Posted August 30, 2021 I have done a fair amount of geo setup on the zed. The factory caster is around 8deg, which is way over âmost road carsâ that run around 4. With my eibach adjustable camber arms (top arms) they allow for changing the caster by around 1 deg each way, i have had to reduce mine slightly to get back in spec. I struggle to think how changing top arms for others designed for a 350z can take 8deg off. I havent seen the moog ones but they will prob be handed. Are you sure they are on the correct side? the other thing to check is toe, if you have a fair amount of toe out, it will make the car wonder off line (but does help turn in/cornering ) like you have experienced. I have never run toe out on rear so unsure if that would effect self centring even if front is ok. You really need to get a full geo/alignment done and see what the numbers are before second guessing. Quote Link to comment Share on other sites More sharing options...
