ZMANALEX Posted September 11, 2021 Share Posted September 11, 2021 Okay, let's take a step back. You have fitted camber adjusting arms to the rear so that should take care of the camber, and you can also fit lock out plates to these. If you are running the stock rear spring carriers then you can not fit standard adjustable toe arms. If you want adjustable toe arms on the rear, you will require something like the image below, (these are what I run) and also use lock out plates, however these are expensive and overkill for your application. Perhaps in hindsight you should have bought a pair of camber arms and a set of toe bolts as a kit. However the toe bolts are available on there own, but please note that the bolt hole in the subframe will require elongated using a template which should be supplied with the bolts, you can not use lock out plates with these bolts. https://www.tarmacsportz.co.uk/spc-performance-nissan-350z-02-08-rear-camber-toe-bolts-pair.html Quote Link to comment Share on other sites More sharing options...
Osakakev Posted September 11, 2021 Author Share Posted September 11, 2021 Appreciate the reply as always. Is it easy to tell if I'm running the stock rear spring? I just know car has HKS Hypermax coilovers. Some toe arms mentioned I needed true coilovers but the Driftworks one didn't so assumed they would be a straight swop from stock. They do look expensive 😮 Just buying toe bolts would be ideal cost wise if that would give enough movement. He mentioned when he got one sorted it threw the other out so assumed I would need lockouts to stop this? Cheers Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 12, 2021 Share Posted September 12, 2021 Please read my last message, lock out plates can not be used with the toe bolts. Just head to an informed geo shop with bolts and template in hand Quote Link to comment Share on other sites More sharing options...
Osakakev Posted September 12, 2021 Author Share Posted September 12, 2021 Thanks Alex. Struggling to find an informed geo shop in North West Quote Link to comment Share on other sites More sharing options...
